586,111 active members*
3,346 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD EXTENDED BOUNDARY HELP
    I was wondering if anyone would be able to help me out with this problem I am having 3axis milling using Bobcad V27. I attached an image for your reference, the face that is in question is the one i marked, I was curious if there was a way to extend the boundary/geometry for this application because how it is now the end mill does not go past the edge of the face so it leaves a little step on the bottom edge off the part, any thing helps i appreciate it!
    Mar 2012
    1570
    Re: BobCAD EXTENDED BOUNDARY HELP
    1) save the file as a new file name, this way any changes you make do not effect the original file.
    2) Extract edges for the top surface of the blade.
    3) Create a UCS that aligns to the geometry
    4) create an offset profile of the surface boundary for how much you want to extend the cut
    5) use that wire frame to create a surface
    6) select the new surface as your drive surface for your toolpath
    Bottom line BobCAD's toolpath is being driven by the selected geometry. Make adjustments to the geometry changes where the toolpath with go.
    If you would like to see a step by step example of this, send me your file and join the BobCAD After Dark Facebook Group, I'll do a live video on your file tomorrow. ( shown in V33, but much of the workflow will carry over to V27 )
Name:	bobcad after dark group image.jpg
    https://www.facebook.com/groups/bobcadafterdark
    Attachment 453958
    Attachment 453960
    Attachment 453962
    Attachment 453964
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  1. 3-D BOUNDARY
    By hst in forum BobCad-Cam
    Last Post: 12-16-2018, 08:27 AM
  2. 3D Toolpath Boundary
    By TonyW in forum BobCad-Cam
    Last Post: 09-25-2013, 04:15 PM
  3. 2D Boundary
    By Damien Gajda in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-03-2012, 09:44 AM
  4. Outside of boundary
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 01-27-2011, 06:16 PM
  5. Boundary box from 9.1 to X?
    By tt_raptor_90 in forum Mastercam
    Last Post: 06-08-2006, 07:24 PM
