Full Disclosure:
I am a complete NEWBIE in the CNC space & know enough to be a danger to myself!
I'm comfortable & enjoy working with wood as woodworking runs in the family.
I'm comfortable on a computer & feel confident that I will be able to learn CNC related software.
1st post here.
...be gentle!
...do I need a safe-word?
Having said that, I've been looking at CNC routers off-&-on for the last 18 months. Sometimes feel that I have paralysis by analysis but believe that I'm ready to buy a machine. Would love to get to the point where I could make a living with the CNC machine and my other woodworking tools but initially looking to start with small projects like toys, signs, small furniture with wood primarily but also adding acrylic projects & a laser & drag-knife. Possibly hooking up with a cabinet maker to cut out cabinets when I'm not using it for my projects.
Based on research and especially because I'm a newbie the positive customer & user support that I hear, I'm looking at at a AvidCNC / CNC Router Parts machine. Specifically a PRO4848. Would love to buy new but hard to justify the price of a new machine right out of the gate.
I found a 5 year old PRO4848 on the second hand market that looks to be in pretty good condition and claims that use has been less than 200 hours.
Here's the specs:
PRO4848 CNC Router Kit
V-CON Linear Motion Rails System
Nema 34 compatible
Z-axis Travel / Gantry Height: 12"/12"
Complete Cable Track Kit
Z-axis Version: 12" Travel Ballscrew
Steel Leg Kit
4-Axis Digital Plug & Play Nema 34 System
Cable Configuration: (2) 12' & (2) 20' cables
Additional Axes: None [4-axis, Standard]
Pepperl + Fuchs Proximity Limit Switch Kit
Auto Z Touch Plate
Bosch 1617 or Porter Cable 690/892 Mount 3.5" Dia.
This is what I think I know about the machine:
It was a great machine when it came out.
The machine runs.
The machine appears to cut true & accurate. (tested by cutting out a circle & a square)
The new PRO4848 has upgraded from the V-CON rails.
The rail & bearings wear after extended use causing less accuracy.
The new leg kit is not compatible with this model due to the V-CON rails.
The 12" z-axis travel may compromise stiffness and flex, especially if upgraded to a spindle & used at high speeds.
The upgrade kit for the unit to be like the current PRO4848 cost $2,295
I do like the option that I can upgrade the machine to a 4896 down the road, if needed, for another $1,650 (after I upgrade to the current model)
So, I'm interested in any & all thoughts from everyone, especially those with a similar machine.
Anyone still using this machine or familiar with these machines:
- any thing I should be looking for besides the wear?
- have you upgraded your machine?
- do I need to upgrade the machine if everything is working & it cuts wood?
- if you did upgrade how long did it take?
- with the current configuration will it work with the 3hp P&P spindle / VFD System that AvidCNC has?
- anything else I should be asking or looking for?
- with the current configuration can this cut soft, thin metals or do I need a spindle to do that?
If I missed anything or you need additional information from me to help answer a question please let me know.
Thanks in advance.
PS Sorry about the pictures. I took a ton more but due to lighting, old phone, idiot user many did not come out.
