586,036 active members*
3,654 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Cannot post job now.
Page 1 of 2 12
Results 1 to 20 of 22
    May 2013
    60
    Question Cannot post job now.
    I reinstalled BobCAD V27 after a harddrive failure. Now I get this error when I try posting a milling job.
    Attachment 454006
    A search of the harddrive does not find the file MillingPostExe_Paths.txt at all.
    None of my settings point to the folder (which does not exist on this machine).
    Attachment 454008
    How can I get this working again?
    May 2013
    60
    Re: Cannot post job now.
    BTW, this is on a Windows 10 machine.
    I have since restarted the computer and retried to post. No change.
    May 2013
    60
    Still Not Working but I have done an uninstall and reinstall, then installed the relevant post processor.
    Now the MillingPostExe_Paths.txt file exists and is in the folder at "Butch Elrod/AppData/Local/Temp". When trying to post (make gcode) I still get the error that it cannot find "Elrod/AppData/Local/Temp/MillingPostExe_Paths.txt" NOTE the lack of Butch at the start. Could the space in the user name be causing this error???
    Oct 2008
    65
    Most likely you need the entire path, something like "C:\Butch Elrod\AppData\Local\Temp\MillingPostExe_Paths.txt"
    Steve
    V28/29 4x Pro, Haas VF-3SSYT, Haas SL-30
    May 2013
    60
    Quote Originally Posted by Alf0412 View Post
    I agree with you but I cannot find where this path is called out in BobCAD so that I can change it. I have added the missing file to the Temp folder named in the settings area. No joy.
    Attachment 454076
    Aug 2012
    9
    Try:
    C:\Butch%20Elrod\AppData\Local\Temp\MillingPostExe _Paths.txt
    May 2013
    60
    Quote Originally Posted by rmalford View Post
    Try:
    Try where? I am not inputting the path. It automatically appears in the error message.
    Aug 2009
    1573
    ...Post Processor in Bobcad v23 it's ...right-click the Milling Tools then Current Settings in the Cam Tree to select file folder. Not sure about V27
    Hope that helps ya,
    DJ
    May 2013
    60
    Quote Originally Posted by machinehop5 View Post
    Hope that helps ya,
    DJ
    It did help me verify that I have the correct post processor installed. Still getting the error that it cannot find this *.txt file
    Dec 2008
    4548
    Thats not a file you are supposed to "Have". It is dynamically created by the posting engine.
    Try close BobCad then right click the icon and choose run as administrator.
    May 2013
    60
    Quote Originally Posted by BurrMan View Post
    Run as admin sounded like a great idea but I still got the same error. Tried with stored text drawing as vcarve and also drew simple part and tried with it. Even changed post processor and still get the same error.
    Aug 2009
    1573
    ... starting to sound like you have a W10 admin problem..or firewall Defender issue.
    https://www.google.com/search?client...ws+10+firewall
    Dec 2008
    4548
    Quote Originally Posted by twoclones View Post
    I would start looking at how you got your installation back to the hard drive...
    I dont fully remember, but i think v27 still had full, initial installers, and update files that were compact and only an update to a full install...
    So, look at your install process. Revisit it if needed.
    May 2013
    60
    I definitely agree but am not finding an issue to correct. I turned off Defender (and the 3 firewalls) then started BobCAD as Admin and tried to post a pretty simple vcarve tool path. Same error
    May 2013
    60
    You lost me a bit here. I have uninstalled and reinstalled twice since initially installing onto the new Win 10 drive. Last time I clicked Yes to all the default choices including the full install.
    Aug 2009
    1573
    ...turning off Defender didn't work. Did you try adding BobCab27 App to the "Allow List" ?
    https://www.technipages.com/blockunb...ndows-firewall
    May 2013
    60
    I have now. Even restarted the laptop then opened Bobcad at Admin. Same error.
    Attachment 454214
    Aug 2009
    1573
    Attachment 454006
    Attachment 454008
    ...after installing Bobcad App did you also have to reload the Post Processor for your type machine Fanuc, Fadal or what ever your machine is?
    May 2013
    60
    Yes. It's a Digital Wood Carver (router) and I still had the original email with the post processor file attached.
    Aug 2009
    1573
    ...I see there was an Update for V27...available. check your Build number to see.
    https://bobcad.com/support/software-...loggedout=true
Page 1 of 2 12
  1. Replies: 1
    Last Post: 04-20-2024, 10:26 AM
  2. Replies: 0
    Last Post: 12-19-2019, 12:12 PM
  3. Replies: 3
    Last Post: 11-30-2016, 07:28 PM
  4. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2010, 07:23 PM
