586,119 active members*
3,626 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Wrap Feature around X Axis Problem
    Jul 2013
    31
    Good day to you all, I am having problems with the X axis Wrapping on a job.
    I want to cut a 60.0 degrees slot x0.250 deep on the OD of a 3.500 dia bar.
    I have calculated the length of the arc to be 1.832" at the 3.5 dia and drawn the curve over the part and then created this as a side feature.
    I thought I could simply use the "Wrap Feature Around X Axis" tick box to generate the feature.
    The angle cut has been measured by inspection and is showing 54.0 Degrees.
    I then proceeded to re calculate the arc length at the 3.0 dia and created a new curve/feature at -0.249 with a 0.001 depth of cut. This time the included angle measured 53.0 deg.
    Any thoughts on what I am doing wrong?
    Many thanks.
    Jul 2013
    31
    Re: Wrap Feature around X Axis Problem
    Update, I think I have found the answer to my question. From Feature Cam Help-
    "When milling features are wrapped around the index axis, one coordinate axis is converted from linear moves into rotational moves. For wrapping around the X axis, the Y axis moves are converted into C axis rotations. For simple wrapping the NC code is relatively simple, but the walls of the resulting feature are not perpendicular to the index axis"
    and
    "If you require perpendicular sides, you must have a lathe or mill with X-axis, C-axis, and Y-axis motion. (I assume this is referring to full 5 axis simultaneous axis movement) "To program your feature to have perpendicular sides you must select Wrap feature around X-axis and also select Cut sides perpendicular to index axis. Features cut with this option have sides that are perpendicular to the index axis"
Name:	Wrap X 2.jpg
  1. NEED HELP ON MILLTURN WRAP FEATURE
    By plast744 in forum CamWorks
    Last Post: 12-09-2014, 12:40 PM
  2. Replies: 2
    Last Post: 09-03-2014, 08:08 PM
  3. wrap axis
    By NiM in forum Esprit
    Last Post: 07-18-2013, 09:09 AM
  4. Using Wrap for 4 axis
    By camtd in forum UG NX
    Last Post: 07-21-2011, 06:01 PM
  5. 4th Axis Wrap
    By brtlatjgt in forum OneCNC
    Last Post: 12-31-2003, 04:11 PM
