586,094 active members*
4,017 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Pinnacle vmc 1100s Meldas 60 cant change tool , Help !!!
    The batteries died and all the parameters got lost but i reinstalled them with help from the original settings for the machine. Everyrhing seems to work except The toolchange , ill White in T02 M06 in Edit and the machine gets the right tool does the spindelorientation and the pot with the correct tool comes down but then it just stopes , The arm wont move. Help whats wrong !
    Aug 2016
    19
    Re: Pinnacle vmc 1100s Meldas 60 cant change tool , Help !!!
    sounds like the part of the toolchange that checks to see if the arm is in position(prox switch) has the wrong param for that. Grab the manual and start learning how to read ladder logic
  1. leadwell w/meldas m50 tool change issue
    By 1600nx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2020, 09:21 PM
  2. Meldas 520 tool change problems
    By Harleycncman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-18-2016, 12:43 PM
  3. cant tool change for meldas 500 m520amr
    By syamct in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-16-2015, 04:23 AM
  4. cant tool change for meldas 500 m520amr
    By syamct in forum Questions or Problems
    Last Post: 04-16-2015, 04:08 AM
  5. Mitsubishi Meldas M65 tool change problem
    By tbilecen in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-20-2010, 12:23 AM
