586,110 active members*
3,181 visitors online*
    Apr 2013
    1788
    Bronze C954 / Aluminum Bronze
    I've been asked to quote on a job using aluminum bronze (C954). I've heard horror stories but have had no personal experience. Is flood coolant required? Any comments regarding DoC/feeds/speeds, tooling, etc.?
    Jan 2016
    99
    Re: Bronze C954 / Aluminum Bronze
    60 pct machinability rating. Lots of tool pressure and picks up heat. So coolant and a very rigid machine help.
    Like most hard materials, easy to get a good finish.
    Tapping with steel taps not fun. 3 to 4 holes is all I ever got on a tap. Better lube than I have may help. When the tap starts squealing I back out.
    Deep parting on a manual lathe, not if I can help it.
    I pretty much needed a new saw blade to cut it.
    Dave
    May 2008
    667
    Quote Originally Posted by kstrauss View Post
    Check price before quoting, very expensive.
    Apr 2013
    1788
    The customer is supplying the stock so I don't care about the cost of material and there are no drilled/tapped holes -- only profile cuts and shallow pockets. Any suggestions regarding feeds and DoC?
  1. Replies: 1
    Last Post: 12-10-2017, 09:57 PM
  2. ALUMINUM BRONZE AMS 4631
    By aerophil in forum MetalWork Discussion
    Last Post: 08-26-2016, 06:21 PM
  3. gibs from oilite bronze sintered bearing material instead of brass/bronze
    By Eldon_Joh in forum Linear and Rotary Motion
    Last Post: 12-19-2013, 10:25 PM
  4. Aluminum Bronze and .062 end milling
    By Vulin in forum MetalWork Discussion
    Last Post: 03-16-2012, 11:04 AM
  5. Two bronze nuts better and cheaper then one bronze nut ?
    By vroemm in forum Mechanical Calculations/Engineering Design
    Last Post: 09-27-2008, 04:18 PM
