586,911 active members*
3,631 visitors online*
Results 1 to 6 of 6
    Dec 2006
    87
    VFD Recommendation plz ! BP Boss 2 hp
    Hey Guys, back to my boss .. typical 2 hp motor .. what's my best choice for VFD
    thanks !
    Joe
    15362
    Re: VFD Recommendation plz ! BP Boss 2 hp
    Quote Originally Posted by mongoose View Post
    thanks !
    Joe
    Almost any VFD will do for your Mill you should get one that can support 240v 10A input minimum, I guess you are using single phase, the input amps is important when you use single phase supply
    I would use a 12A input rated VFD Drive for this motor
    Mactec54
    Dec 2006
    87
    thanks Mac,
    this is the drive i ended up ordering
    10.5 FLA and includes braking transistor
    https://www.factorymation.com/TD400-2003-13PH
    the bigger ones were all 3 phase input so hope it works !!!
    Joe
    15362
    thanks Mac,
    Joe
    3 phase input has nothing to do with it, a 3 Phase input VFD Drive still runs on Single Phase don't believe what a sales person tells you
    A 3hp that you got should do the job with having the braking resistor, the Rated Input Amps that the Drive can use is what is important when using Single Phase supply that needs to be a minimum of 10A for your motor so that is 10Amps on the input not the output of the VFD Drive if it can't do that then send it back and get one that can
    Mactec54
    Dec 2006
    87
    Mac, thanks for the input.. i have reached out to this company to find out the input amps... The rated output current (A) is 10.5 and the rated input current (A) is 23.9 / 12.5 depending upon if you are using single or three phase.
    15362
    That would be fine if those numbers are correct would make this drive quite good for other Spindles, as well it has a good safety factor @ 23.9 A
    Mactec54
  1. Specs and pics on Bridgeport Boss 5 thru Boss 12
    By Sakoman in forum Bridgeport / Hardinge Mills
    Last Post: 12-10-2016, 10:21 PM
  2. Boss 10 Retrofit options / need Boss 10 Diagrams
    By panozeng in forum Bridgeport / Hardinge Mills
    Last Post: 08-25-2015, 06:47 PM
  3. Replies: 17
    Last Post: 06-11-2008, 01:19 PM
  4. Homing boss 8 or boss 10
    By wcarrothers1 in forum Bridgeport / Hardinge Mills
    Last Post: 06-05-2008, 02:06 PM
  5. Boss 9 Boss 10 parts swop
    By Drewboy in forum Bridgeport / Hardinge Mills
    Last Post: 03-30-2006, 05:16 AM
