Re: Ram-type milling machine
Originally Posted by
peteeng
Hi luka - lamepox is a laminating resin and is suitable for your bonding requirement. If the gap is very thin then use neat. Can add some Al if you like. If you are bonding I recommend applying to both surfaces first and allow if to soak in for a while then add more and join together. If the surfaces are porous and you apply then bring together the material may soak up some Epoxy and then the joint will be a bit dry...You have 2 hrs before gel so don't panic. You can put the joint together and pull it apart to check if all the surface is wet... Peter
Peter, I think he is wanting for filling gap in base to column joint.
I don't think pulling apart and looking is viable. Takes a long time to move heavy stuff and it has to be precisely aligned.
Have a filler tube feeding the joint and pour in until full / top up. Silicone around edge of joint to seal after aligning and before putting in epoxy.
