586,754 active members*
7,586 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Closed loop stepper positioning
Results 1 to 6 of 6
    Jun 2015
    8
    I'm completely new to cnc, and of course, I have a problem:
    https://www.cnczone.com/forums/attac...d=454444&stc=1
    I will make a linear guide ( 1605 ball screw, hiwin rails, chinese close loop stepper Nema 23) that will close the two piece die set, and it's contact surfaces needs to be without any gap.
    The question is how to achieve the perfect positioning every time? ( gap between the contacting surfaces needs to be ''zero'').
    Dec 2013
    5717
    Re: Closed loop stepper positioning
    Jog the die closed, set 0 there, then just move to 0 each time.
    Normally this type of thing is done with an adjustable mechanical stop for maximum accuracy.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    8
    Thank you!!!
    So, adjustable mechanical stop on the dies side (right?), and maybe a limit switch on the other side of the rail?
    The only concern is repeatability on the dies side, but I guess it depends not just of my closed loop stepper, but my linear rail, too?
    Thanks again,
    Marco.
    Dec 2013
    5717
    Normally for an application like this you would use an air cylinder, hydraulic cylinder, or a crank shaft.
    The cylinders can be adjusted with an adjustable hard stop at the die side.
    The crank shaft with an adjustable length connecting rod, can be adjusted to the exact shut height required.
    The design in the picture would be self limiting, because 0 is a hard stop.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    8
    I understand.
    I'll consider a cam shaft for this project.
    Thanks a million,
    Marco
    Dec 2013
    5717
    Quote Originally Posted by bochketuning View Post
    I understand.
    Thanks a million,
    Marco
    Yes, a cam would work also. I built one small press that had a cam, worked very well.
    Jim Dawson
    Sandy, Oregon, USA
  1. Closed loop driver with open loop stepper motor
    By trikan in forum Stepper Motors / Drives
    Last Post: 05-22-2020, 03:26 AM
  2. Recommendations on closed loop stepper set please
    By dazp1976 in forum Stepper Motors / Drives
    Last Post: 09-10-2019, 12:36 PM
  3. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  4. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  5. Closed loop positioning in Mach 3
    By saabman in forum Charter Oak Automation Support Forum
    Last Post: 04-06-2011, 10:55 AM
