586,060 active members*
4,300 visitors online*
Results 1 to 19 of 19
    Aug 2007
    24
    RFQ - small aluminum bracket
    Here are list of features:
    1. rough stock size is 3.75" x 2.25" x .5"
    2. 2x 6.4mm clearance holes
    3. 2x M6x1 tapped hole
    4. 1x M5x.8 tapped hole
    5. 1x slot
    6. outer profile
    7. machine top and bottom surfaces.
    Aybody with a small milling machine can do this. Quantity will depend on the price.
    Aug 2007
    24
    I need a quote with and without the three threaded tapped holes.
    Apr 2005
    86
    Drawing? Without a drawing there are too many questions left unanswered. If you want an accurate quote provide a drawing.
    Jan 2007
    7
    could you fax a print to me at (580-234-1687)
    we have a hurco vm3
    Mar 2007
    67
    How wide is the slot, length and depth and are the tapped holes through?
    Please advise either in this forum or by contacting us via e-mail to:
    [email protected]
    Regards
    AMW
    Aug 2007
    24
    Provide me with a fax number and I will send it over. Chipmaker6, the drawing is on it's way. Please ignore all the GT&T and tolerances. The drawing acutally looks more intimitaing than it really is. It doesn't need to meet all those details. I could care less if this part was made with a hacksaw, drill, and a dremel tool
    I can send a dxf file in 1:1 scale. You can then glue the template on to the aluminum block and just cut out the shape. I'm thinking this will probably be the cheapest way to make this part.
    The slot is trianglular, with generous radius on the 3 corners. a=(1.2") b=(.5") c= (1.25")
    All the holes and slot are thru.
    I'm looking for quantity of 1 to start and then up to 100, after the fitment check.
    Aug 2007
    24
    chipmaker, I just faxed you 1:1 scale print
    Oct 2006
    43
    drawing?
    can u post or email a drawing?
    Jul 2005
    236
    Aluminum bracket
    Quote Originally Posted by chris9911 View Post
    5. 1x slot
    6. outer profile
    I would need some more imformation in order to quote, such as outer profile,top and bottom machine surfaces and hole location.
    Aug 2007
    24
    I will send the print out to a fax machine. Please ignore all the GD&T, it makes the part look lot more intimidating than it really is. I could care less if you used a hacksaw, drill, and a dremel tool to make this
    The slot is trianglular with generous radius on all three corners. a=(1") b=(.5") c=(1.125") All the holes and slot are thru-all.
    If you have a manual mill, I can send you a drawing in 1:1 scale. You can then cut it out and glue it onto the aluminum block to mill it. Maybe this will be the cheapest way to make this part.
    I'm looking at quantity of 1 to use for a fittment check. I will then probably need up to 100 afterwards.
    Aug 2007
    24
    I don't want to make the drawing public. Please give me your fax machine and I will send it over immediately.
    Jan 2007
    7
    i cant read your number on the fax you sent
    Jan 2007
    7
    can you email me your phone #
    [email protected]
    Aug 2007
    24
    410-465-6977
    Mar 2007
    67
    Please fax your drawing to us @ the following #: (847)232-3167
    Thank you!
    AMW
    Chris,
    If you send me a fax I can give you a realistic price.
    (317)876-9108
    You could also send me a drawing thru my website.
    Anthony Holmes
    http://quicksilvermetals.com/
    Jul 2007
    39
    small alum. bracket
    could you fax a print to (405) 224-6689
    Jul 2007
    39
    Bracket
    Your 1pc. would be 31.00 including material and shipping
    If you order 100pcs. it would be 27.00 ea. including material, not shipping
    Brian
    Aug 2007
    24
    JOB IS COMPLETE.
    Thanks everyone.
  1. RFQ - Aluminum Parts - small job
    By F500 in forum Employment Opportunity
    Last Post: 06-08-2007, 09:30 PM
  2. Request Closed: Small Aluminum CNC Job
    By gravydrive in forum Employment Opportunity
    Last Post: 05-30-2007, 04:47 PM
  3. Need some aluminum bracket help
    By sin-city-custom in forum Employment Opportunity
    Last Post: 08-08-2005, 01:05 PM
  4. contouring aluminum with small bit
    By corpse in forum Benchtop Machines
    Last Post: 09-14-2004, 07:11 PM
  5. Bending small aluminum rod
    By Twmaster in forum Bending, Forging, Extrusion...
    Last Post: 08-07-2004, 01:50 AM
