586,075 active members*
4,035 visitors online*
    Aug 2007
    22
    Unhappy Leadwell ECOTURN-250 Fanuc-0TF
    Good day. Please help me figure out the C-axis. There is no documentation for the machine. I describe the problem. I enter the command M90 (C-axis is active) I refer the C-axis to zero, everything is fine. With the M91 team, I switch to normal spindle operation, everything is spinning. I re-dial M90 C0 and the axis does not get into the correct position. shows C 000 but really no. It is necessary to manually re-reference the C-axis. Then the C-axis is at zero. I don’t know how to work with her?
    Nov 2009
    19
    Re: Leadwell ECOTURN-250 Fanuc-0TF
    Before activating c (m90) run m19 (Spindel orientation) . Also remember to rewind the c-axis to zero before deactivating c (m91).
    If you dont rewind, zero will change next time you activate c.
  1. Leadwell, fanuc O-T help!
    By Vegabond in forum Fanuc
    Last Post: 02-19-2019, 03:40 AM
  2. Electrical manuals for Daewoo Homa Ecoturn 2000
    By newbie_cnc in forum Daewoo/Doosan
    Last Post: 07-17-2013, 04:38 PM
  3. FANUC 18-M LEADWELL
    By PICMAN in forum Fanuc
    Last Post: 11-14-2011, 03:21 PM
  4. Leadwell Fanuc ot unıt
    By mustafaguler in forum Fanuc
    Last Post: 05-26-2011, 11:48 PM
