I want to know how i can post process my ipt file to heidenhain without using the cycles of heidenhain.More specifically I want when I am making a circular pocket to process this in simple commands and not to use the 252 cycle of heidenhain . The problem is that the specific cycle when it end the process it does not move to the center of the circle and makes a little lead out and then it moving up .When I am using a woodruff cutter or a T cutter this will make a problem . I hope that I made myself clear and to someone could help me. Thanks !
