586,051 active members*
3,697 visitors online*
Results 1 to 6 of 6
    Aug 2016
    4
    DIY Laser engraver/cutter
    Hi all
    I have designed my own Laser engraver/cutter
    Design done using Fusinon360 (free for hobby use)
    - MGW12H rail fro the y-axis
    - MGW7H rail for the X-axis
    - Laser module/kit from Opt Lasers https://optlasers.com/kits-and-adapt...r-cnc-machines
    - Software LightBurn https://lightburnsoftware.com/
    Controller - not decided yet, but for the first test I i use the Mini Gerbil controller form awsometech https://awesome.tech/product/mini-ge...-laser-cutter/
    But I need more axis (Mini Gerbil only have 2 axis) for my Z and rotating axis
    I`m going to test:
    - Smoothieboard5x running smoothieware or GRBL-LPC
    - GRBL-HAL Teensy 4 https://github.com/phil-barrett/grblHAL-teensy-4.x
    I do not know what is the best controller for a diode laser / LightBurn
    First mechanical test:
    This laser kit comes with a nifty magnetic docking that makes it simple to remove the laser when not in use or when you want to swap lens/clean the lens..
    Next:
    • Connect and test laser
    • z-axis (moving bed)
    • Rotary axis
    • Camera for LigtBurn (8MP)
    Oct 2010
    46
    Re: DIY Laser engraver/cutter
    You have a pretty neat setup.
    I wish to add laser system to my CNC router one day. However, I will need to update
    my controller I suppose to be able to control the ON/OFF of the PWM laser...
    I am in hurry to see someone using their new model "PLH3D-15W", it looks awesome.
    However, there's not so much hype about it and because of price not alot of people
    seems to buy their components.
    They seems alot better quality than the chinese typical ones we can see everywhere.
    AXYZ Millennium router CNC: https://goo.gl/gxvdcA
    Glass cutting CNC table: https://goo.gl/VrDqGD
    Mar 2021
    Hi !
    Have you done any other tests with PLH3D?
    I ask because the topic is from December
    And did you establish something about controller for diode laser?
    Aug 2016
    4
    After spending some time using this laser I learned some things.
    Make an enclosure/cabinet so you can get a fan for smoke/exhaust extraction + protection from the laser light
    I want to test a corexy setup for my Opt Lasers module and combine this with a new "boxed" design
    As controller I`m going to use the grbl HAL Teensy Pro in combination with the Light Burn software
    The design is not final - working on a setup for my Z-axis + I`m going to install the electronics in the lower section in some kind of drawer
    Aug 2016
    4
    I`m going to test this as my "work surface" (with more spikes). The spikes are 10mm - i`m going to use this in combination with magnets to keep the material in position
    My z-axis (dual MGN12H + dual screw)
    Attached Thumbnails Attached Thumbnails 228786715_197911865549177_3574176018278841127_n.jpg   229119286_227877095884631_1017311329737504623_n.jpg
    Aug 2016
    4
    In this test I control the controller using LightBurnTesting different layers with different laser power (led display)+ controlling the solenoide valve for air assist per layer in LightBurn
  1. Replies: 3
    Last Post: 05-20-2022, 03:27 AM
  2. Replies: 3
    Last Post: 08-18-2015, 04:13 AM
  3. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
