586,119 active members*
3,665 visitors online*
    C02 Laser Erratic Power Output
    Hello,
    I have an inexpensive, 40W CO2 laser which has been working great for my simple uses. I had been using it without problem last week. Then, the next day, I went to turn it on and nothing... After some investigating, I determined that it was a power supply failure, so I ordered a replacement, which, after installed works fine. However, I started noticing that I was not getting the normal power output as I was before and, when cutting at full power, the beam looks "grainy" and erratic. I also noticed an electrical "buzzing" sound that was not there before. So, I ran the cutter with the tube exposed so I could see what was going on; this is what I saw (see YouTube video): https://youtu.be/uCVXQ97J7dI
    Before running this test, I replaced all my cooling water with new, distilled water and ensure that there were no air bubbles in the tube's cooling chamber.
    I fear the worst, that my tube has somehow failed (even though I have not used it that much), but would like some other opinions.
    Thanks!
    Nov 2010
    787
    Re: C02 Laser Erratic Power Output
    Laser power supply is first suspected.
    CNC lasers, constructions, service
  1. How to measure real laser power output?
    By murnyanskaya69 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 06-24-2018, 01:09 PM
  2. Laser Output Power, pulsed and average
    By jpwade in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-27-2018, 02:06 PM
  3. Chinese 40w laser power output not consistent
    By kwiktsi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2017, 05:57 PM
  4. Lasea 100W CO2 Laser low power output
    By LemonSaurus in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 10-06-2014, 04:50 PM
  5. Measuring power output of laser
    By greybeard in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2006, 07:25 PM
