586,065 active members*
4,349 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Bar feeder BF1200 Controller Fanuc 0i-TD
    Sep 2019
    30
    I want to to change my sub program for bar feeder and I need some help.
    Right now after feeding the bar is finished, the spindle starts, but my push road is still inside in spindle.
    I want the push road to be outside the spindle back in bar feeder and after spindle to start.Can anyone help me?
    O9001(ELEC. BARFEEDER SUB-PROGRAM)
    IF[#1000EQ0]GOTO10
    G0W50.M19
    M72
    #100=0
    WHILE[#1001EQ0]DO1
    G04X0.1
    #100=#100+1
    IF[#100GE#615]GOTO2000
    END1
    G0W-47.5
    M65
    M71
    M98P8020
    M99
    N10M72
    M65
    M71
    M99
    N2000#3000=1(BF NO EJECT)
    O8020(ELEC. BARFEEDER SUB-2 PROGRAM)
    G0W50.
    T0606
    G0X-50.G96S180M3
    Z0.
    X-19.M8
    G1X5.F0.2
    X0.5F0.08
    G0X-19.
    M99
    M63 BAR FEED ALARM CHECK
    M64 CANCEL END OF BAR
    M65 BAR SUPPLY FINISH
    M66 BAR FEED LOAD IN
    M71 CHUCK CLAMP
    M72 CHUCK UNCLAMP
    Nov 2009
    19
    Re: Bar feeder BF1200 Controller Fanuc 0i-TD
    Is it going out of the Spindel, but don't get fully retracted before the Spindel starts?
    Nov 2009
    19
    Quote Originally Posted by vanova20 View Post
    IF[#1000EQ0]GOTO10
    G0W50.M19
    M72
    #100=0
    WHILE[#1001EQ0]DO1
    G04X0.1
    #100=#100+1
    END1
    G0W-47.5
    M65
    M71
    M98P8020
    M99
    N10M72
    M65
    M71
    M99
    G0W50.
    T0606
    G0X-50.G96S180M3
    Z0.
    X-19.M8
    G1X5.F0.2
    X0.5F0.08
    G0X-19.
    M99
    M71 CHUCK CLAMP
    M72 CHUCK UNCLAMP
    Im not familyar with your barfeeder, but i have this https://www.scribd.com/document/4034...2017-11-20-pdf
    On my model I control the retract-point on the feeders control panel, an not in the G-code.
    But if its starting rpm, before fully retracted, i would run a feed-cycles in singleblock to localize where it happens, and add a Dwell-time.
    Sep 2019
    30
    yes
  1. Replies: 1
    Last Post: 07-06-2020, 05:17 PM
  2. Bar feeder oil choices to help with vibration inside the feeder channels
    By lasernerd in forum CNC Swiss Screw Machines
    Last Post: 05-19-2017, 10:59 PM
  3. WEDM Fanuc alpha 1A controller Fanuc 16WA
    By sinad in forum EDM Discussion General Topics
    Last Post: 02-14-2016, 08:20 PM
  4. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
  5. Replies: 0
    Last Post: 09-27-2010, 04:00 PM
