very true but i just did another trick that worked
the relay on that bob luckily is a spdt relay, they used 2 pins only, all i needed is to use the 3rd pin
which means when the relay is off it can be a fw or a rev state to the vfd, not the perfect solution but it worked as it should, now m3 and m4 does work
thanks a lot for your help
