586,108 active members*
3,115 visitors online*
    Lathe repeat cycle
    Hi all, very new to this, Have an ORAC that I have had to convert because like me it is old and it lost its tiny little mind, I forgot EPROMS don't hold on for ever.
    With the ORAC I used G73 start do loop and G06 end do loop, I now see there is G75 for pattern repeat in CNC TNG, does the TODO in the G-Code reference guide mean it is not implemented yet?
    Is there any other way of creating a repeat cycle without creating multiple copies of the same code?
    Thanks, Chris
    May 2008
    266
    Re: Lathe repeat cycle
    Quote Originally Posted by VeteranChris View Post
    Thanks, Chris
    Yes.
    Menu > Machine > Start Options > Start Loop ...
    Martin.
    Thanks Martin
    Tried it, it is very limited, repeats the whole program, so I will have to break the program down into blocks and run 1 block at a time.
    Chris
    Mar 2017
    1312
    Make subprecedure containing your g-code. Then execute subprocedure multiple times in a loop.
  1. CNC or cycle lathe
    By siedler0_1 in forum Turning Machines
    Last Post: 01-22-2019, 09:56 AM
  2. quick tip: Using Repeat function and proper End Repeat.
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 10-13-2015, 10:42 AM
  3. G-Code repeat cycle
    By Me2 in forum G-Code Programing
    Last Post: 11-02-2011, 01:22 AM
  4. How to Repeat in G81-cycle with G91
    By brinchen in forum Okuma
    Last Post: 03-06-2009, 03:38 AM
  5. Repeat lathe tools
    By steveo in forum Mastercam
    Last Post: 05-03-2003, 05:42 PM
