586,060 active members*
3,925 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Now EzCad2 is discontinued is it time to investigate more into how it works ?
    Since EzCad2 is discontinued and EzCad3 is a pretty expensive retrofit of software and control board (at least) might be time to poke over how it works more .
    The XY2-100 for the galvo is easy enough, the Raycus 8 bit power + sync seems fairly straightforward since its tight timing either cpu+fpga/cpld+ram as a driver, or just keep figuring out the LMC1 interface. Maybe BJCZ will update/give out the EzCAD2 SDK instead.
    Oct 2019
    7
    Re: Now EzCad2 is discontinued is it time to investigate more into how it works ?
    Is anyone out there using EzCad3?
    Cheers.
    Bill.
  1. 60w mopa and ezcad2
    By charliex in forum Laser Control Software
    Last Post: 05-09-2021, 02:53 PM
  2. DM542? Discontinued?
    By LazyMan in forum Leadshine
    Last Post: 03-01-2021, 07:19 AM
  3. Has Artcam been discontinued?
    By Gary-Wiant in forum ArtCam Pro
    Last Post: 04-05-2019, 05:49 PM
  4. ATC Macro works 95% of the time
    By abcncfab in forum Mach Wizards, Macros, & Addons
    Last Post: 06-25-2016, 09:34 AM
  5. M6 Command only works one time now with new computer setup
    By jevs in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2013, 06:53 AM
