586,119 active members*
3,518 visitors online*
IndustryArena Forum > MetalWorking > 80/20 TSLOTS / Other Aluminum Framing Systems > Looking for advice on long length 80/20 fixture
    Dec 2020
    Hello,
    I am am doing a project that isn't a CNC but would like to use similar components. I am wondering what suggestions people may have.
    I would like to build an 80/20 frame that has a 2'x2' footprint and is 8' tall. The frame would carry a payload no more than 50 pounds. Initially I am looking to have this frame travel 20' but it could end up going as far as 40'
    Any suggestions for a kit/parts that could mount to an 80/20 track? I want to avoid as much drilling and cutting as possible but then also use components that would be robust. Any thoughts too if this could use just one motor or if it would need two racks and motors?
    Thank you
    Apr 2004
    5737
    Re: Looking for advice on long length 80/20 fixture
    If you're not willing to tell us what this machine is supposed to do, we won't be able to tell you how to make it work. You've got a tall skinny box with 50 pounds dangling from it, and it's supposed to travel 40 feet?
    Andrew Werby
    Website
    Dec 2020
    Yes
    Jan 2014
    4
    80/20 has roller wheels of various types: https://8020.net/panelsdoorcomponents/rollerwheels.html
    Given how tall and narrow your contraption is, I would add "override" wheels or brackets underneath the tracks so that if the contraption is disturbed or tries to tip, it will not fall over/off the track.
  1. tool length to long
    By laamar in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-15-2021, 11:02 PM
  2. Looking for long length reamer
    By ranchak in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-14-2017, 05:34 PM
  3. long length bevel cutting
    By siegfried_74 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-29-2015, 03:34 PM
  4. Long length bevel cutting
    By siegfried_74 in forum Hypertherm Plasma
    Last Post: 04-26-2015, 01:51 PM
  5. Long length engraving bits / needle
    By Loonie1989 in forum CNC Tooling
    Last Post: 11-16-2012, 09:40 AM
