586,119 active members*
3,420 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > STAMA MC 530 1995 FANUC 16M all parameter lost
Page 1 of 3 123
Results 1 to 20 of 43
    Dec 2020
    19
    Hello
    I have a problem. I lost my all parameters from machine. Machine is empty. Im lost ladder and other parameters. Maybe there is a person who has such a machine and can download the parameters from the machine to me?
    Apr 2009
    1379
    Re: STAMA MC 530 1995 FANUC 16M all parameter lost
    What makes you think that the ladder is gone? The (nc and pmc) parameters I understand, but not the ladder or system files.
    Dec 2020
    19
    I have problem and alarm with RAM parity. Then I reset memory, then i lost parameters and lost ladder. Earlier I had a problem with a computer that was being repaired, possibly it was the cause.
    I have parameters files to backup and got ladder files from factory. How to upload ladder to the ROM? Which files are from ladder?
    Oct 2009
    297
    Quote Originally Posted by pablowlkp View Post
    Hello:
    You don´t need to upload the ladder. Once you reset the machine, (clear memory) you should see many alarmas indicating you lost all parameters. Why would you enter the Boot system (System check screen)? Do not do anything in there.
    The ladder should appear as soon as you enter all Nc parameters.
    Regards
    AlexFanuc
    Dec 2020
    19
    Quote Originally Posted by alexfanuc View Post
    Hello:
    Regards
    AlexFanuc
    Thanks. I'll try.
    I went into system screen because I think I deleted the PMC file by accident. One file is missing.
    Oct 2009
    297
    Thanks. I'll try.
    Do you have the main PCB part number?
    Dec 2020
    19
    This number is on main board: FANUC 16MB A02B-0200-B503 / MAIN FS16B , CPU board number is A16b 3200 0010/07A
    Post all of the M5301159.#xx files. I can convert these files to a MEM file that you will be able to load into your machine.
    Dec 2020
    19
    Quote Originally Posted by drdos View Post
    All files in RAR.
    If you convert this files , can I load this files to ROM? or where ?
    Attached Files Attached Files
    Oct 2009
    297
    All files in RAR.
    Hello:
    Becareful when uploading files into the Boot System.
    Do not upload files if you already have them in the system.
    The file that you probably erased was PMC-RB.000
    Regards
    AlexFanuc
    Dec 2020
    19
    First I will install the parameters files, and when the ladder is gone it will load ladder file.
    Dec 2020
    19
    Hello:
    Regards
    AlexFanuc
    PMC-RB.000 is Ladder file?
    Oct 2009
    297
    That is correct. It should be in the system files.
    regards
    AlexFanuc
    Yes, you have it?
    All files in RAR.
    You have to copy it onto a Flash card and load it in that way. The file is here ready to load. It's called PMC-RC.000. The controller doesn't care what the file name is as long as it's a ladder file. You load it BOOT mode under System Data Load. (I added it to your rar file).
    Dec 2020
    19
    Thanks, I try it
    Dec 2020
    19
    Hello
    I load the PMC-RC file into the ROM on the machine.
    I can see the LADDER in the machine yeah
    I have a problem. I have two alarms:
    -ER07 NO LADDER STEPS OPTION
    -WN17 NO OPTION (LANGUAGE)
    I think this problem is because I don't have PMC parameters loaded on my computer. How can I load these parameters to the machine from my memory card? I have four files from the factory (attached). What extension should the files have?
    I'm having trouble loading files from my PC because I can't select EDIT mode on my computer.
    Apr 2009
    1379
    Loading system files and parameters should be done in MDI mode (default) and E-stop condition.
    I didn't see any CNC Parameters among these files. Did you load these? The errors that you are getting are related to option parameters not set to support that ladder that you installed. 9900's parameters is where these are stored. ALL CNC parameters must be loaded first.
    Oct 2009
    297
    Hello
    Hello:
    I agree with DRDOS. You have not loaded option parameters.
    Load CNC parameters and you will be able to see the ladder.
    Regards
    AlexFanuc
Page 1 of 3 123
  1. Parameter lost in Wasino CM-3 with Fanuc OM
    By microinv in forum Fanuc
    Last Post: 12-04-2018, 05:52 PM
  2. Lost parameter Fanuc 15-M
    By ronniostrem in forum Fanuc
    Last Post: 11-28-2017, 05:01 PM
  3. Replies: 0
    Last Post: 01-07-2015, 08:48 PM
  4. Fanuc 0M-C ---Parameter lost
    By rajappa in forum Fanuc
    Last Post: 06-13-2008, 12:25 AM
