586,062 active members*
4,500 visitors online*
Results 1 to 7 of 7
    Dec 2020
    Non Machinist needs advice & help
    Hi all very new here, just signed up. This is going to sound pretty ass backwards but I have just bought a Syil X7 which will be delivered in a few weeks and i know nothing about machining or very little.
    Just a short explanation, i have a partnership in a workshop in Perth WA, we are pretty specialised in Electronics Sheet Metal and Screen Printing which has nothing to do with machining right? We have been outsourcing a small aluminium enclosure for many years now, we run 100 or so at a time 5/6 times a year & they have been very stable at that level but more importantly they are just 1 of many products we make for this customer. They know it's not what we do but it works for them & that's fine by us.
    What i'm hoping for is some advice on software & maybe some help to get my head around it and perhaps as far as help to program this unit & suggestions the best way to approach this job. The enclosure is two part a Lid & Base
    Lid = L 125mm W 79mm H 15mm
    Base = L 125mm W 79mm H 25mm
    Controller
    SIEMENS Sinumerik 808D/A
    Travels
    X-Axis 15.7" (400mm)
    Y-Axis 11.8" (300mm)
    Z-Axis 14.9" (380mm
    Table Size
    27.6" x 11.8" (700mm x 300mm)
    Jan 2008
    1529
    Re: Non Machinist needs advice & help
    Photo or drawing of the finished part?
    Just cut outs of a stock aluminium box?
    Do you have other designs / parts to make?
    May 2015
    686
    I'm assuming this enclosure is machined out of billet. I have a friend who does a lot of similar work on an older Syil based on a Seig SX3 mill. HF enclosures and the like with even the screws set at 1/4 wavelength apart. Sounds like its ideal for a syil.
    I had a quick look at my ally supplier's catalog (Action Aluminium - who is not in WA) and he does not list any suitable bar stock. So I would ask him to cut strips 80mm wide from 16mm and 25mm flat plate which he will do.
    So I would start by doing the rounds of the suppliers over there and see how they can help you out.
    Plus I'd take a sample to a couple of machinists and talk to your existing contractor to see how they would do it.
    My friend now uses Fusion 360 for CAM even if he works in other CAD programs.
    Rod Webster
    www.vehiclemods.net.au
    Dec 2020
    Thanks for replying Rod, I have the material stock sorted, I don't think my contractor would be too pleased to know he won't be getting the job anymore & probably not keen too advise us. Yes it seems a lot of people are liking Fusion 360, i fell out of love with AutoCad a few yrs back so not keen on their products. thanks for your thoughts I appreciate it.
    Bill
    Dec 2020
    Thanks for the reply,
    Photo or drawing of the finished part? - it's a screenshot from my CAD
    Just cut outs of a stock aluminium box? - No it's milled from two different sized billets
    Do you have other designs / parts to make? - Hopefully but not right now
    Jan 2008
    1529
    Quote Originally Posted by jempro View Post
    I don't see any attachment / photo on any of your posts.
    May 2015
    686
    Bill
    I won't say I'm liking Fusion after using Solidworks. Its different I will say but I am better with it now
    Rod Webster
