Hi folks, I am changing my thrust bearings in a Fadal 3016 X axis and I need to realign the screw, I am a bit at a lost on how to do that for what I understand I would follow this steps after the ball screw is instralled...
1.- Tighten the ballnut to the table leaving the mounts finger tight. (should this be done mid travel on the ballscrew?)
2.- Move the table to the the thrust bearing side and tighten that side.
3.- Move the table to the carrier bearing side and tighten that side.
4.- Move the table to the middle of the travel loosen and then tighten the ballnut mount.
Does that sound correct? Thank you all in advance
