586,047 active members*
3,903 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > ESS Smooth stepper and a import mpg wiring
    Nov 2007
    361
    I just got my ESS in and I am trying to get my mpg pendant hooked up and going . I found the docs on the warp9 website but it does not explain where the 5 volts are coming from for the mpg power , com signal , and e stop com wire . It says wires that are tied to 5 v (wires that don't go to the Smooth stepper Input pins ) are MPG power (mpg vcc ), E stop Common Signal and axis and rate Common Signal (com). It never says where these wires end up going to ??? I have had some tell me that the com wire goes to ground but this is telling me it goes to 5v ? Does anyone have this setup ? can anyone help me in the right direction ? The picture shows where all the wires should go beside the ones talked about above and the pic on the right is explaining the com signal wire but never says the location
    Attachment 455566 Attachment 455568
    Feb 2021
    Re: ESS Smooth stepper and a import mpg wiring
    Quote Originally Posted by Michael82 View Post
    did you find a fix, if so can you share please
    Nov 2007
    361
    Quote Originally Posted by MadKezza View Post
    Yes I can give you the info I have , I have moved on to centroid acorn, no more mach3/4 , and no more smoothstepper . The deal with my mpg i was having to get 5 volts to power the mpg so I just ran a wire from my ess and got the 5 volts from there. It does not explain that in those instructions in the quote but if you need anything else let me know
    I am at work right now but if you would like when I get off this evening I can take pictures of how I have it connected
  1. KL-Series Drivers, Leadshine and Similar Import Drive wiring
    By datac in forum Automation Technology Products
    Last Post: 12-15-2017, 09:35 PM
  2. Replies: 9
    Last Post: 10-09-2016, 10:56 AM
  3. Wiring import plasma for CNC use
    By TS Offroad in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-20-2015, 03:17 PM
  4. Replies: 3
    Last Post: 08-08-2014, 02:01 AM
  5. Smooth Stepper Need Help
    By Mad Welder in forum SmoothStepper Motion Control
    Last Post: 09-24-2011, 04:21 AM
