586,071 active members*
3,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Cadet "Stroke End Over Travel "
    Aug 2017
    8
    Hi Guys .
    Im stuck on the X axis and looking for help on getting the axis back to normal.
    I did make sure the stroke is back at the factory setting to save my tail.
    My problem is whats what here .
    Is it a press switch or a toggle switch that needs to be activated.
    Here is what I have found in my manual and a picture inside the cabinet
    Please advise the proper way to get the machine off the alarm
    And Happy New Year
    Aug 2017
    8
    Re: Okuma Cadet "Stroke End Over Travel "
    OK
    So I got the machine to move, but its not moving the correct way,.
    My Factory stroke Settings are
    P 365.2417
    N 351.4622
    What do I need to open them up to make this work and also why is it not moving in both negative and Positive directions ??
    Its moving out and I want top move in...
    Mar 2009
    1982
    Technically it is not complicated. More details and specific would help a lot.
    1. What happens between time point "machine is working correct" and time point "today" ? Some maintenance/ lack of maintenance ( dirt collected ) ?
    2. What is status of hardware limit switches.
    3. The tumbler "Stroke End Cancel" must be back to 0 ( off status ) when the axis moved away from the limit point.
    4. Look if axis moved to parameter stroke limit doesn't touch the hardware limit switch.
  1. Replies: 1
    Last Post: 02-01-2019, 11:28 AM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. 20x40x20 travel "cnc ready" bed mill frame
    By springlakecnc in forum Want To Buy...Need help!
    Last Post: 04-17-2013, 03:08 PM
