586,058 active members*
4,575 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Need LaserCad - Sinjoe Closed and my AWC708C Plus "communication unsuccessful"
    Jan 2011
    171
    I have a Sinjoe with an AWC708C Plus. I had been running it off LaserCad 7.66 but had to get some computer work done and had to re download LaserCad. Now, after re downloading 7.66, 7.88 AND 7.95 I can get my laptop to recognize the machine when connected by cable but I get the "communication unsuccessful" line when downloading projects to it. Even old saved projects that downloaded fine in the past will not work. The MachName: AWC708C is the Select Mode. Sinjoe apparently is out of business so I haven't been able to get any service there (the website is gone). Used to work with a guy named Felix. Any ideas?
    Nov 2008
    643
    Re: Need LaserCad - Sinjoe Closed and my AWC708C Plus "communication unsuccessful"
    I use this same controller on a home built machine. The controller has a section containing parameters that define machine hardware. The only way I can set/modify parameters is with the software provided with the controller. I guess the machine vendor would have provided that but there are other sources
    Lightburn has a DSP version that does a great job managing drawings and communicating to the controller. Can’t seem to use it to set parameters.
    You may want to try lightburn. I communicate using Wi-Fi from lightburn which is very convenient. It also has a USB input.
  1. inexpensive nema 17 "closed loop" stepper driver
    By WhiteHare in forum Stepper Motors / Drives
    Last Post: 08-19-2020, 09:50 PM
  2. Need Help / Communication Unsuccessful
    By Rahken in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2018, 01:46 PM
  3. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  4. Replies: 1
    Last Post: 05-16-2015, 11:29 PM
  5. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
