586,036 active members*
3,620 visitors online*
    Post Safop HT12 cnc lathe
    I have a newly installed lathe (fanuc 31i controller ) had a problem that, quill stroke is 300mm. but once we forward quill about 50mm in jog mode, turn to auto mode, machine alarm shows that, Quill is not in position for auto cycle. This machine is Italy made and this machine tool is no more. kindly any body knows the setting or thrust adjusting in some parameter please suggest.
    Dec 2009
    953
    Re: Safop HT12 cnc lathe
    there is a pressure sensor or proximity sensor that is not working,look for it
    Quote Originally Posted by zavateandu View Post
    Everything is fine and working. The requirement is only thrust setting in machine parameter is not known. K
    Hope any other similar Safop lathe and its setting procedures will help me .
    In Control panel PMC status DB3804 setting for center 60 degree or 90 degree . Please suggest if any one already use this for sleeve or quill setting
  1. Replies: 4
    Last Post: 05-03-2018, 04:14 PM
  2. Replies: 0
    Last Post: 05-05-2017, 06:45 PM
  3. CAD/CAM for 3-in-1 lathe/mill combo with lathe spindle stepper motor
    By KevMoto in forum Uncategorised CAM Discussion
    Last Post: 04-30-2014, 08:59 PM
  4. Replies: 1
    Last Post: 05-29-2009, 07:47 AM
