On a 2005 TL-1, the Servo wires come in on the Left side of the electrical panel.
On mine, there is a large square plastic fitting that attaches to the harness, then goes into the side of the enclosure. A bulkhead fitting.
I have some cracked of flex conduit I wanted to replace. I know the two connectors going to the servo and encoder are molded on so wouldn't be able to slide that flex conduit off that end, however does anyone know if the other end comes off (the bulkhead fitting at the enclosure end)?
Richard
