We've just got a new pc at work to replace our old workhorse that is controlling the Chinese laser cutter.
The problem is that the laser now occasionally cuts while traveling and only half-finishes cutting lines (see picture). We are using the most recent version of RDWorks and the pc is directly connected to the laser cutter. We did not have any problems with the old setup which coincidentally ran an older version on RDWorks.
The new pc is a cheap laptop with weak specs (since its only function is to run RDWorks) and sometimes it gets a "connection error" when trying to "go scale" or starting a job.
Can this be the cause of the problem and how do we fix it? Thanks!
