587,008 active members*
3,300 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Running partner 1 Centurion V software on XP desktop / Has anybody done this ?
    Dec 2015
    Recently I copied ALL of the files on my Milltronics Partner 1 Centurion V machine to my Old XP machine for safe keeping.
    Since confined to quarters so-to-speak I decided to try and configure the software to actually run on my XP.
    It Works SORTA,
    Of course any command specific to machine movement causes an error, but the rest does work, HOWEVER,
    All of the text labels in the F1-F10 keys are displayed as some other unreadable code set as well as the top line status bar,- time, file name, path ect.
    Everything seemed to work but how those labels are displayed
    I looked around and found Simulator software 5.94 but on my XP it does the same thing
    Has any one been able to run this on a 2002+ windows machine
    Jul 2010
    548
    Re: Running partner 1 Centurion V software on XP desktop / Has anybody done this ?
    Try loading a copy of your parameters in the PC.
    Dec 2015
    Quote Originally Posted by sportybob View Post
    I tried reloading the parameter file and it yielded the same results.
    I did find another post here on the zone of the same situation and the solution is to use DosBox, that does work. That thread was regarding simulator 5.94 software
    there is a link to simulator software but it is version 5.79, my machine has 5.75
    So you can run the machines program on an XP system with DosBox but you need to put all of the folders in the root directory and edit the path.dat to reflect that.
    I suspect that the issue is the machine has a VGA card running 640x350 and modern desktops have SVGA or better
    Thanks for viewing
    Mar 2021
    11
    I have spare milltronics controller Centurion 5 CNC 2.97
    Floppy drive included
    Must go.
  1. MILLTRONICS Partner 1 Centurion 6
    By sen2two in forum Milltronics
    Last Post: 04-10-2018, 12:31 AM
  2. Partner 4 Centurion 4 E Stop
    By cheapo in forum Milltronics
    Last Post: 09-10-2016, 04:56 AM
  3. Replies: 1
    Last Post: 07-26-2014, 10:25 PM
  4. Milltronics Partner III / Centurion IV
    By JoshuaJ in forum Milltronics
    Last Post: 12-22-2011, 05:14 AM
  5. Partner IV w/Centurion V Problems
    By KurtsKustom in forum Milltronics
    Last Post: 05-10-2008, 01:53 AM
