586,077 active members*
3,591 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > doosan lynx 2100 lsya turret unclamped
Results 1 to 6 of 6
    Feb 2011
    353
    I have a new (2020) doosan lynx 2100 lsya
    i had a tool sticking out to far toward the sub spindle and when it went to clamp it couldn't
    the tool has been removed so there is no interferance
    but still have the following alarms
    2146 servo drive overheat
    2118 turret clamp/ unclamp
    does anyone know of the procedure to reset the machine
    Feb 2013
    788
    Re: doosan lynx 2100 lsya turret unclamped
    Call my cell. (973) 803-9479
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2011
    353
    dhardt thanks for the opportunity to give you a call i appreciate it very much
    able machine got back to me and did a good job of helping me out
    1st attempt was E stop then try and move the turret by hand
    2nd attempt was change a keep relay to activate the turret to un-clamp move the turret sightly and re clamp the turret this worked very well
    Mar 2021
    Quote Originally Posted by rcs60 View Post
    Hi, we have a doosan lynx 2100 lsy. What was the procedure you used when you changed the keep relay? We are currently waiting on someone we know at able to get back to us and we are sorta dead in the water currently.
    Feb 2011
    353
    Nickbabz I'm not at work at this time but will be at work sat. morning where i can get you the procedure
    Feb 2011
    353
    I think that the keep relay is k8.3
    if it's a 1 change it to a 0
    if it's a 0 change it to a 1
    Not sure which one it will be ?
    the turret should un-clamp
    put the turret as close as possible to the correct position for clamping
    if it doesn't clamp try it again
    then change the keep relay back to the original setting
  1. Doosan Lynx 300 Turret alignment
    By Ally369 in forum Turning
    Last Post: 08-23-2019, 06:35 PM
  2. Doosan lynx lm 220
    By Anisk in forum Daewoo/Doosan
    Last Post: 12-18-2017, 09:28 AM
  3. lynx doosan 220
    By tpsimer in forum MetalWork Discussion
    Last Post: 02-08-2014, 06:27 PM
  4. Duplomatic 300 turret unclamped
    By dbarath in forum Colchester Tornado lathes
    Last Post: 05-07-2011, 10:53 PM
  5. Doosan Lynx 220 Gang Tool or Turret?
    By abhthree in forum Daewoo/Doosan
    Last Post: 10-22-2010, 02:56 PM
