586,106 active members*
3,134 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Need Help! Problem to make a toolpath without segments
    Jan 2021
    Unhappy Need Help! Problem to make a toolpath without segments
    We are trying to use Bobcad-Cam V30 for our production.
    The problem here is that application compute the toolpath of a straight line or radius into many segments.
    Is there any way to fix the the issue? Or, is there any setting that we can edit it?
    Attached Thumbnails Attached Thumbnails Screen Shot 2021-01-07 at 9.41.17 AM.jpg
    Mar 2009
    1982
    Re: Need Help! Problem to make a toolpath without segments
    what prevents you from CAM'ing manually? Can you attach the picture of the part?
    Usually the result of broken geometry or not having "use Curves" turned on.
