586,047 active members*
3,855 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Building a Gatton Machine. Need help selecting parts
    Jan 2021
    I bought the bare bones CNC "Kit" from Gatton (basically just wood parts) https://www.davegatton.com/ and the instructions are a bit limited beyond building the physical frame.
    First
    the Gatton Plans recommend the dumpstercnc.com "Gatton CNC Kit" for the Leadnuts: 1/2"-10 ACME 5 Star, Flanges: .980 Cutdown flange with (2) .173" dia clearance holes, Couplers: 1/2"-10 ACME 5 Start (2 turns per inch),
    Gatton CNC Anti-backlash Kit. I am checking to see if a better kit is recommended
    ($150-300)
    Second
    I would like a few good recommendations on controller kits (complete)
    (under $1,000)
    fyi..
    This is 100% a hobby for me and I am looking to just learn on this build and see if I like it. I am also Checking to see what size everyone recommends as far as the bed dimensions, would I be far to limited with a 4'x4' or should I go to 4' x 6'?
    Jun 2014
    Re: Building a Gatton Machine. Need help selecting parts
    I highly recommend you review Dave's build videos. There are others on YouTube as well.
    You are limited by the length by the acme screws, 4x4 cutting area is possible. The dumpstercnc kits work. I bought the JaviBox which also works. Something that has caught my eye is the https://buildbotics.com controller. Dave recommends a smaller size but I built mine as large as the screws allow and I get a 5x4 cutting area. Good luck with your build.
  1. Looking for the Dave Gatton plans
    By bwc0263 in forum DIY CNC Router Table Machines
    Last Post: 10-06-2016, 03:58 AM
  2. building parts of my machine from acrylic?
    By rotccapt in forum DIY CNC Router Table Machines
    Last Post: 04-20-2013, 01:35 AM
  3. selecting parts from spider.dxf
    By helpmeout in forum CamBam
    Last Post: 11-11-2012, 10:47 AM
  4. need help in selecting parts for cnc router
    By sahilkit in forum DIY CNC Router Table Machines
    Last Post: 07-30-2009, 04:09 PM
  5. Sourcing Parts - help with selecting a shop
    By tikka308 in forum Employment Opportunity
    Last Post: 06-28-2007, 03:12 PM
