586,123 active members*
3,140 visitors online*
Results 1 to 8 of 8
    Aug 2006
    5
    Question Ladder editing
    Hi all.
    I would like to edit the ladder on a Mazak Integrex 3rd serie machine with MTPro control, to do some minor changes (of course under my own responsability), as I did through the years on my Fanuc based machines.
    Does anyone know the way to do it right at the machine through the M62monitor program ? Or: which program to do it on PC ?
    Many many thanks in advance to everybody will help me.
    Aug 2006
    5
    Anyone?
    Sep 2007
    217
    Be careful and back it up before trying anything. Best to do it on the machine just remember you need to shut down the machine to get most ladder mods to take effect. Also you void the warranty if you do if it is still under one.
    Aug 2006
    5
    Thankyou for the tips. Warranty is finished, so I could give it a try. The only *little* problem is I have to enable the "write" feature and nowadays I have no idea about how to do it! Manuals don't say nothing (I will notice Fanuc did an opposite choice)
    Sep 2006
    48
    Editing the ladder can be easilly done on a Matrix control, sicne all the tools are provided inside the control. Obviously you need to be in priveleged mode.
    I've never tried on a 640, but if you can get to where you can see and monitor the ladder, I'll bet you'll find you can edit it and make the change. The trick is to load it back into permanent memory so the changes stick.
    Mazak clearly won't tell you how it's done. tracking down a mitsubishi PLC programming manual will help out though...
    Aug 2006
    5
    Still no luck, that "WRITE" button remains hidden. Hope there's someone new who can help me, the list of minor changes I need to do on the ladder is growing day by day.
    We have 25 Fanuc based machine, of course all of their ladder are editable, and 3 Fusion machines still waiting to perform some change. Surely we won't make again the mistake to buy a CNC without this feature, but today we *need* to find the way. Hope someone is hearing my cry! All the best to everybody
    Apr 2009
    31
    HI Luca_l,
    It's easy to modify 640MTPro system ladder.
    Just login password ,then let "write" highlight.
    Because 640 system is not same as Matrix with address description, not easy to check the logic.
    Have anybody know that how to edit 640 system PLC on PC same like Matrix ?
    Thanks.
    Aug 2006
    5
    > Just login password
    Hi. Which password and where ?
    Thankyou
  1. PMC Ladder backup on 16MA
    By figeacaero in forum Fanuc
    Last Post: 12-27-2018, 12:32 PM
  2. fanuc-o ladder
    By Bill Clark in forum DNC Problems and Solutions
    Last Post: 09-29-2011, 07:35 PM
  3. ladder descriptions
    By ktb100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2006, 02:04 AM
  4. Fanuc ladder editing card
    By bob1371 in forum Fanuc
    Last Post: 04-10-2006, 04:50 PM
  5. Ladder logic
    By Chris Roth in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-26-2005, 05:29 PM
