586,036 active members*
3,793 visitors online*
Results 1 to 1 of 1
    Oct 2007
    1022
    creatbot ed large printer (have an in with the supplier)
    Creatbot D600Pro:
    build volume 00x600x600mm
    dual nozzles resolution .05 1.75 filamant dia
    various nozzles diam--.3---1.0
    filament compatibility pla,abs, carbon fiber, wood,nylon,pc, pteg,hips,pp
    flexible,tpu,pva, peek etc
    nozzle temp 350 degrees max,,bed temp 100 degreesmax, chamber 70 degrees max
    drying temp 65 degrees
    print speed 45mm/sec to 120mm/sec
    automatic leveleling
    auto shut off on power failure orfeed supply fail
    220volt single phase
    touch screen usb connect
    supports STl,OBJ,AMF
    size 915x845x1085 mm at 125kg weight
    opsystem supported windoes 7,8,10 and Mac OS
  1. Large 7075 aluminum block supplier
    By Texasbr in forum Want To Buy...Need help!
    Last Post: 03-14-2014, 01:37 AM
  2. My large 3d printer i built
    By dick cnc in forum 3D Printer / 3D Scanner Discussion
    Last Post: 08-09-2013, 12:12 AM
  3. Large format printer.....wax maybe?
    By Master of nun in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 04-30-2013, 04:30 AM
  4. Looking for a supplier-LARGE Aluminum billet/extrusions
    By rmarchjr in forum Want To Buy...Need help!
    Last Post: 02-07-2011, 05:11 AM
  5. Large format printer teardown
    By agonsw in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-07-2010, 04:02 PM
