Hi
Is It Possible To Help Me For The Following Problem:
In Fanuc 15ma Control System With Bmi Pmc, Spindle Don't Rotate Neither From Control Panel Neither By Command From Mdi Mode.
In Ladder There Are Two Contact In Sequence For Running M3 And M4 , First One Is F Type Register Which Activiate By Command From Mdi , The Second Is R Register With Address R500.2 Which Is Not Activiated.
Drive And Controller Are Safe. What Can R Register Related To?
Is It A Parameter? Or May It Be Wire Connection Problem?
Or Other Item ?
Your Respond Is Appreciated In Advance.
Mehdif
