586,242 active members*
3,619 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > XHC wired MPG/pendant in Mach3 - unwanted motion on x axis?
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jul 2007
    7
    Re: XHC wired MPG/pendant in Mach3 - unwanted motion on x axis?
    Quote Originally Posted by dustmakernc View Post
    Congrats! I took your suggestion and d/l'ed LinuxCNC, got it installed and spent a few minutes with it. I was in the process of getting the LHB04B-4 setup when I realized that LinuxCNC doesn't support my USB BreakOutBoard - I would need to change to a parallel port driver, so I kind of stopped there. If I am going to swap out the BOB, I'll go with an ethernet model.
    Keep us posted on your progress with the LHB04B-4. I like the hardware for the most part and I'm eager to see how yours turns out. Maybe I'll make the leap to linuxcnc after all.
    I fiddled with this some more today. After editing your /etc/udev/rules.d file, the terminal command "xhc-whb04b-6" show find the device right out of the liveCD with no recompiles required. The "-u" option will print a hexdump of the communication between the computer and the pendant. "-p" prints only when you press or release a button and does not report on the wheel. Hope that helps. Let me know if you need some help with LinuxCNC and I'll muddle through with you.
  2. #22
    Feb 2005
    750
    Has anyone else had any issues with the LHB04B pendant? I see they are also sold at CNC4PC.com, just curious what others have experienced with this device? Does it operate well and work similar to a wired pendant or not?
    Halfnutz
Page 2 of 2 12
  1. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  2. X axis homing in Mach3 with a CS-Lab motion control board
    By Exhibitology in forum CS-Lab CNC Products
    Last Post: 05-03-2016, 07:32 PM
  3. Unwanted motion during machining
    By danielcoyle in forum Commercial CNC Wood Routers
    Last Post: 12-14-2014, 09:04 PM
  4. Replies: 5
    Last Post: 09-04-2014, 12:49 PM
