If you were to request new features to be added into the Torchmate 2 drivers software, what would they be? No idea is too wild so let the imaginations fly!
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
I would like to be able to resize a DXF file after it was transfered from cad to the torchmate software.
thanks
Should have worded it better. For example, torchmate's art clip files that comes with the software is already, DXF files so you don't use the CAD program. I wanted to resize some of them in the torchmate program. the whole thing, not just a object in it. Can you do that now?
thanks
you can change scale in the torchmate driver software when import DXF file.
For example,change scale 1 to 1.5 or 2 and so on,but is suit for one object.
reed
I would like to be able to change the orientation of the DXF file (horz. to vert. or flop)
also I would like to use the pendent with the THC control (Turn the tourch on and off,raise and lower)
JDDurham
Also Mike I’m upgrading our TM 2 this week and every thing is working fine this is one good reason why to buy a tourchmate system they can be modified very easily to whatever spec. You need
I will post the whole project next week
JD
The DXF file will always be oriented using the bottom left X- and Y- corner. How you draw your parts in the CAD, or how your motor configurations are set-up, will determine how things are oriented on the table.
