586,105 active members*
3,322 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Advise on Buying a Haas 1997 VF-2
Results 1 to 9 of 9
    Dec 2006
    947
    Hi, I have the opportunity to buy a 1997 Haas VF-2. It came out of shop that took care of it. The machinery company that is selling it for the shop did a whole bunch of tests. It has a lot of hours on it 20,537, but the accuracy tests seems OK. Below are some of the report numbers. I could get it for $5000, maybe a bit less.
    What do you all think? Worth it for that price? It does have a USB retrofit to upload gcode.
    Motion time: 20537.34 , Tool changes: 742825,
    Check level of machine. x In Spec. x Re-leveled
    X/Z Squareness (Reading ) x In Spec. o Out of Spec.
    Y/Z Squareness (Reading ) x In Spec. o Out of Spec.
    Y/X Squareness (Reading ) r In Spec. r Out of Spec. Axis backlash X (Reading ) o In Spec. o Out of Spec.
    Axis backlash Y (Reading .0003 ) x In Spec. o Out of Spec.
    Axis backlash Z (Reading .0004 ) x In Spec. o Out of Spec. Spindle sweep (Reading .0006 ) o In Spec. x Out of Spec.
    Notes/Recommendations: did not check squareness do not have granite and customer not having tolerance issues at this time. Spindle sweep out there is roughness in spindle when running not sure if coming from spindle or motor further diagnosis needed. Not causing tolerance issues at this time.
    Dec 2006
    947
    Re: Advise on Buying a Haas 1997 VF-2
    No one, really? Bump. Sad Face.
    used machines are like used cars
    if it runs smooth and makes a decent part then 5k is a pretty good deal on a vf2
    Dec 2006
    947
    Thanks. I was more looking for any major problems with that year and model. I know older haas's have has problems and or design flaws.
    I like the older controls better than the newer ones myself . I used to run a vf2 that was somewhere around the same yr and saw minimal issues with it . Good machine overall .
    Dec 2006
    947
    Cool. Thanks. Now just gotta find somewhere to put it. LOL
    spindle noise is the obvious thing to look for but how do the ballscrews bearings sound when you jog ? What state are the slides in , will they leak coolant out the back of the machine when using flood . How does the spindle taper feel and are there any signs of someone using grit to polish imperfections on that taper ?
    If everything looks and sounds good then you'll have a lot of machine for the price , not much can be had for 5 grand these days
    slide covers I meant to say
    Dec 2006
    947
    I haven't seen it in person yet. Still doing my research. But I know the shop it came out of and it's been in storage, been inspected and tested by a machinery company. Hence the numbers in the first post. But I'll check that all out when I go to inspect.
  1. advise buying cnc mill machine
    By dylan0806 in forum PCB milling
    Last Post: 10-19-2015, 06:12 PM
  2. 1997 Haas HL4 shutting down
    By GeorgeTurning in forum Haas Mills
    Last Post: 07-08-2013, 11:08 PM
  3. Buying steppers soon need advise...
    By SatanKlawz in forum DIY CNC Router Table Machines
    Last Post: 12-02-2009, 04:39 AM
  4. Buying advise, EZ Trak SX or Prototrak MX2
    By HammerHands in forum Bridgeport / Hardinge Mills
    Last Post: 11-03-2006, 11:43 PM
  5. Advise on buying a Lathe
    By crease-guard in forum Uncategorised MetalWorking Machines
    Last Post: 04-01-2006, 05:30 AM
