586,384 active members*
3,658 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Program select from floppy
Results 1 to 8 of 8
    Oct 2009
    114
    Hi everybody
    Our LU 15M machine is running from disket driver but MB 56 machine doesn't run from floppy diskett driver.
    ?t gives 5261 error
    Mar 2009
    1982
    Re: Program select from floppy
    What is your point? You want to transfer part program from the lathe to MC ?
    In my understanding both LU15M and MB56 should run even with floppy drive detached, but most likely it is not your question here.
    Oct 2009
    114
    I mean program select and cycle start
    Mar 2009
    1982
    clear. First of all, do you see ( on OSP ) the contents of the floppy?
    Is the floppy Okuma OSP format or MS-DOS format?
    Oct 2009
    114
    Yes I see inside of floppy. It is OSP format.
    Aug 2009
    1573
    ..720 or 1.44 format
    5,25 disk?
    Oct 2009
    114
    1.44 format copying ok but program select no it is option or parametric ?
    Aug 2011
    419
    Quote Originally Posted by MCR-B II View Post
    Program select from floppy is option.
    it is a special function and can be activated.
    "Imagination is more important than knowledge."
  1. USING MACRO/SUBROUTINES TO SELECT BOLT HOLES IN A PROGRAM
    By bulldozer55 in forum G-Code Programing
    Last Post: 03-05-2019, 09:10 PM
  2. USING MACRO/SUBROUTINES TO SELECT BOLT HOLES IN A PROGRAM
    By bulldozer55 in forum Joes CNC Model 2006
    Last Post: 12-13-2018, 09:32 PM
  3. Can't load program from floppy
    By dresda in forum Milltronics
    Last Post: 07-24-2011, 03:04 AM
  4. Program tool pot select on an umbrella?
    By calgarykevvy in forum Okuma
    Last Post: 12-05-2010, 12:18 AM
  5. Program load/select list on V2XT Boss XT 3.4 control
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 02-23-2007, 03:36 PM
