586,058 active members*
4,285 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Please help me calculate stepper motors.
Results 1 to 8 of 8
    Aug 2012
    23
    I have a CNCRouterparts PRO 4"x8" from 2014. It has been unused for a few years, and when I wanted to start using it again my PC was broken so I do not have the original MACH3 settings.
    I then upgraded to UCCNC software and AXBB-E motion controller. I've got it all running but I can’t figure out how to calculate my stepper motors. And right now my brain is burning from messing with it all day.
    I found this calculation from cncrouter parts https://www.avidcnc.com/pro-rack-and...-34-p-226.html I hope it is the same specifications on the 2014 model. and I have a DQ860MA drive which is currently set to 1600 micro steps. But I do not mind if it is changed.
    in fact I would greatly appreciate if you have any suggestions for the best settings!
    Could someone please help me figure out what to write in UCCNC to get it up and running?
    Also I am from Denmark so I do everything in mm not in inches.
    Jan 2016
    386
    Re: Please help me calculate stepper motors.
    Can you pull the hard drive from the old PC and install it in another PC or external HD case so you can access the mach3 directory? If so all the settings you used would be available to you.
    Aug 2012
    23
    Quote Originally Posted by Steve303 View Post
    No it’s all gone.
    Aug 2012
    23
    Anyone!
    Apr 2010
    82
    Quote Originally Posted by Gunni View Post
    Anyone!
    The attached file (mach3 profile) will get you started. The site does not allow xml files, so I have renamed it to TXT.
    Aug 2012
    23
    Thanks but I do not have mach 3. is there no one at all who will help me along the way?
    Jan 2016
    69
    Wish I could help. I also have a CNC router parts set up but use Mach4. Have you thought of calling up Avid/ CNC Router Parts and asking them?
    Sent from my iPhone using Tapatalk Pro
    Apr 2010
    82
    What specifically is needed? Steps per unit? Velocity/acceleration?
  1. How to calculate what stepper I need?
    By atferrari in forum Mechanical Calculations/Engineering Design
    Last Post: 08-05-2010, 12:41 AM
  2. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  3. how to calculate RPM for 5phase stepper motor
    By skalaxy in forum CNC Machine Related Electronics
    Last Post: 03-13-2009, 01:12 AM
  4. How to calculate required stepper torque for indexer project
    By 3IMOH in forum Stepper Motors / Drives
    Last Post: 01-09-2008, 11:28 AM
  5. How to calculate the voltage for a stepper
    By Big John T in forum CNC Machine Related Electronics
    Last Post: 10-29-2007, 07:57 PM
