586,111 active members*
3,148 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Finally moving up to VFD and Spindle - Looking or confirmation on some points
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    15362
    Re: Finally moving up to VFD and Spindle - Looking or confirmation on some points
    Quote Originally Posted by SamHam View Post
    According to my book:
    PD175 = Inverter model
    PD176 = Can be set to 0-50Hz or 1-60Hz Factory is 0
    PD120 = Stall Prevention - 0-200% Factory is 0
    PD010 = Min Starting Voltage Factory is 8 for 220v class
    I have not changed any of these (including the 06,09,07,10
    I should be safe leaving them at Factory, except for PD120. If left at 0 that would disable stall protection. So that I would change to 100.
    Does that sound workable?
    Some of the different models has some slight differences in there manuals
    Correct PD120=100
    Factory Defaults are for a 50Hz or 60Hz Ac motors, they do still work but are not what your 400Hz spindle should have
    Mactec54
  2. #42
    Apr 2015
    72
    I cant find anything more than this on the spindle.
    Voltage 220
    Current 10amp
    Phase 3
    Frequency 0-400Hz
    Speed 0-24000rpm
    Collet ER20
    Bearing Ceramic
    Where / what more should I be looking for?
  3. #43
    15362
    Voltage 220
    Current 10amp
    Phase 3
    Frequency 0-400Hz
    Speed 0-24000rpm
    Collet ER20
    Bearing Ceramic
    I guess it is 2.2Kw or is it 3Kw
    Mactec54
  4. #44
    Apr 2015
    72
    2.2Kw
  5. #45
    Apr 2015
    72
    Mactec54,
    Any more thought on what
    PD006=
    PD009=
    PD007=
    PD010=
    should be for a 2.2 air cooled spindle?
  6. #46
    15362
    Mactec54,
    PD006=
    PD009=
    PD007=
    PD010=
    Sorry I did not think you where up and running again, I will do some, air cooled what was there recommended minimum speed this is important
    Mactec54
  7. #47
    Apr 2015
    72
    They did not have a recommended min speed. I currently have it set to 6000 (100Hz)
  8. #48
    15362
    That is normally to slow for air cooled spindle so you will have to try it and see if it over heats at that speed some have to be as high as 150Hz to keep them cool enough it will depend how efferent the fan is at low speeds
    Mactec54
  9. #49
    Apr 2015
    72
    Even though I have run it at 6000 for up to 30 minutes without it getting warm (just breaking it in), I don't really need that low a speed except for occasional drilling. I could adjust my settings to 120Hz (7200) easy enough.
  10. #50
    Apr 2015
    72
    I've changed my VFD to 120 for minimum speed. Any more input for
    PD006=
    PD009=
    PD007=
    PD010=
    Now?
Page 3 of 3 123
  1. Spindle smoke - confirmation
    By markokaz in forum Spindles / VFD
    Last Post: 02-01-2020, 10:21 AM
  2. Start Points Keep Moving
    By ITGuyOX in forum BobCad-Cam
    Last Post: 01-16-2017, 03:01 PM
  3. Replies: 0
    Last Post: 10-20-2014, 07:13 AM
  4. Spindle Confirmation
    By partsman in forum Haas Mills
    Last Post: 03-22-2012, 04:42 PM
  5. 6 points moving
    By MCR-B II in forum Okuma
    Last Post: 10-21-2009, 05:14 AM
