586,114 active members*
3,348 visitors online*
    Jul 2007
    13
    Exclamation Stepper for Spindle Speed
    Hi! I want to retrofit a Lathe with 2 axis movement. I want to use a stepper for the spindle movement (rotation). is it possible to make a continious movement at high speed (about 1300 RPM) on large times with and stepper?.
    Mar 2004
    1543
    A srepper would be a poor choice for the spindle. Steppers lose torque rapidly as speed is increased.
    I would reccomend a three phase motor and VFD. Inexpensive and much more capability.
    Karl
    Mar 2005
    1673
    Jul 2007
    13
    thanks for the response!! but I still have a question: it is possible to make a follow up of position and speed of the spindle with an encoder an a G-Rex or PMDX? a mind for threading.
  1. Spindle speed not 100%
    By AndyB in forum Fadal
    Last Post: 07-14-2007, 02:52 AM
  2. Spindle Speed
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 01-28-2007, 05:40 AM
  3. spindle speed
    By Mike Boarman in forum Machines running Mach Software
    Last Post: 11-28-2006, 04:37 AM
  4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  5. Low speed spindle?
    By cbass in forum Uncategorised MetalWorking Machines
    Last Post: 02-25-2005, 10:38 AM
