586,082 active members*
3,837 visitors online*
Results 1 to 8 of 8
    Mar 2010
    60
    Secondary Oiler
    Attached photo of second oiler fitted to 770.
    Mar 2020
    218
    Re: Secondary Oiler
    I assume you've split the feed lines between the two oilers to create more consistent oiling between x/y and z?
    Mar 2010
    60
    Re: Secondary Oiler
    Yes that is correct. If it were easy I would add a third oiler so each axes had its own feed. If I ever, god forbid have to remove the X axis table I would be tempted to change the connections to allow for this..Only then, would have a better idea that each axis are getting a good supply or not. I don't often use flood coolant so not over fussed with extra way oil contaminating coolant.
    Jan 2021
    Re: Secondary Oiler
    Instead of using a separate oiler, has anyone tried using a progressive valve distributor? They work well with grease but have never tried with oil.
    Aug 2020
    106
    Re: Secondary Oiler
    Attachment 456580
    I did the same. Seems as if Z suffered as it had upward flow to contend with...the path of least resistance and all that. I personally just feel better about it now. I bought 4mm push to connects so it was just disconnect from original fittings, cut old fitting off and push into new one. Literally 5 minutes.
    Oct 2009
    483
    Re: Secondary Oiler
    Quote Originally Posted by Bbt View Post
    Something like this from Ray (SczEngrgGroup) ?
    https://www.cnczone.com/forums/novak...tic-oiler.html
    Jun 2014
    1780
    Re: Secondary Oiler
    I installed a second oiler for the Z axis as well a few months back, works great.
    I also use magnets to hold the bellows in position so that I can check the oiling without such a hassle of removing all the screws that arent readily accessible.
    mike sr
    Jan 2021
    Quote Originally Posted by Titaniumboy View Post
    Wow that is very neat. I was meaning more like this.
    https://www.hudsunindustry.com/product/ssv10-progressive-divider-valve/
    Downside is that if one line blocks, none will get oil/grease.
    Usually have a proximity sensor on one output to ensure that the unit is working.
    https://youtu.be/U7UN1jmT7P8
    Link explaining how they work.
  1. G29 Secondary Home, HOW?
    By rjCousineau in forum Haas Lathes
    Last Post: 09-03-2013, 06:06 AM
  2. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  3. Omniturn OT Secondary Offsets
    By HBFixedGear in forum Uncategorised MetalWorking Machines
    Last Post: 05-25-2009, 01:08 AM
  4. Need more I/O on secondary paralellport
    By corydoras in forum Controller Cards
    Last Post: 01-12-2008, 08:18 PM
  5. Toroid second secondary?
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 08-18-2005, 06:53 PM
