586,069 active members*
3,538 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Trumpf press brake protective beam
    Jan 2021
    Hello. I ask for advice, trumpf trubend 3100 problem gives an error, the beam protection system does not work. dark pixels of the beam, it is not possible to calibrate the protective field.
    May 2007
    15
    Re: Trumpf press brake protective beam
    Maybe some pics would help. Beam height match tooling?
