586,121 active members*
3,572 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > KmotionCNC DRO font alignment issue after font change
    May 2017
    7
    Sorry, this probably seems a bit type A and unimportant to worry about, but I've been making a custom UI for KmotionCNC with the Screen Editor and ran into an issue after changing the font on the axis DRO section. After the font change, the font wants to center a bit when the numbers are changing rather than staying fixed like before. For example, the "X" in the X axis DRO indents a tad and the coordinate number indents a tad from the right as well, centering itself in the box. I'd really prefer the X never move and that the decimals stay aligned like before the font change. I'm a bit committed to the font now because I've invested a ton of time creating custom button bitmaps using that font, so I'm hoping I can tweak this. Any ideas?
    May 2006
    4045
    Re: KmotionCNC DRO font alignment issue after font change
    It seems you double posted this question here.
    TK
    http://dynomotion.com
    May 2017
    7
    Quote Originally Posted by TomKerekes View Post
    Sorry for the repeat post. I figured I'd pop it into both forums in case different folks kept up with the separate forums. Thanks again for the help!
  1. How To Change the default font
    By SPEEDRE in forum Autodesk
    Last Post: 08-24-2012, 04:12 PM
  2. Font change
    By mori4200 in forum SIEMENS -> GENERAL
    Last Post: 04-12-2010, 07:20 PM
  3. How to change ugly font
    Last Post: 03-15-2009, 05:13 AM
  4. Single line font issue
    By pcbmiller in forum Uncategorised CAM Discussion
    Last Post: 03-24-2008, 08:06 PM
