586,469 active members*
3,102 visitors online*
Results 1 to 6 of 6
    Aug 2008
    303
    hole size cutting smaller than program
    I just finished converting a router table and this is my first test piece.
    Everything works great, and all dimensions but one are right on size except the 2 1/2" diameter hole in the center.
    For some odd reason, it measures 2.420" ??
    I really have no clue why just that one hole would have machined smaller.
    Hopefully someone has an idea.
    I'm using OnShape for my .DXF drawings, and Dolphin CAD/CAM to generate the G-code.
    Machine is running on Mach4 with ESS.
    I've enclosed the drawing, but I'm unable to post the complete .TAP file used to cut the part, so I posted the first part of the program because the 2 1/2" hole gets machined first.
    I will also ask on the Dolphin Cad forum.
    Thanks for any help.
    Dan
    Apr 2004
    5741
    Re: hole size cutting smaller than program
    I'm not familiar with Dolphin, but it sounds like the sort of error you get when you intend to have the tool run on your circle, but instead it runs inside it. There's usually a setting that specifies whether the cut is inside the line, on the line, or outside the line.
    Andrew Werby
    Website
    Aug 2008
    303
    That's not the problem. If it ran "on" the line, the hole would be .250" smaller ( it's only .080" smaller)
    The odd thing is that the other contours are dead on size including the four .375" dia holes that were programmed the exact same way as I programmed the 2 1/2" hole. (pocket clear cycle)
    The one that dies with the most tools, WINS !!
    www.dantechfabricating.com
    Any way to post the code for the center hole bigger? Can't see a thing. Also include what size tool you're using.
    Nov 2013
    4413
    in most CAM softwares there is a setting <Stock to Leave>. It is usually set to 0.1mm or similar on a roughing toolpath
    and is intended to be cut in the final finishing pass. Is it possible that this operation has inadvertently got <Stok to Leave> set?
    Craig
    My guess would be a mechanical issue.
  1. cutting wrong size hole
    By macplus in forum Uncategorised CAM Discussion
    Last Post: 11-30-2014, 11:23 PM
  2. Break Project into smaller size
    By Mr.Chips in forum Vectric
    Last Post: 12-16-2012, 02:27 AM
  3. Spur Gear size - Direct Drive...smaller is better?
    By mikemaat in forum Linear and Rotary Motion
    Last Post: 09-11-2011, 09:41 PM
  4. Smaller vacuum hold down for Taig size mill?
    By sp1nm0nkey in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-14-2010, 02:43 PM
  5. Making a hole in aluminum smaller
    By flatfnder in forum MetalWork Discussion
    Last Post: 02-15-2010, 07:27 PM
