586,497 active members*
2,965 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Tool Radius Compensation Usage?
    Mar 2016
    18
    What is the correct setup and usage for tool radius compensation? The manual and post examples don't cover the topic very well. I'd like to set it up to use compensation values stored on the machine.
    Feb 2006
    183
    Re: Tool Radius Compensation Usage?
    This will only work for 2D-Profiling.
    1) Go to madCAM options / 2D Options and click the "Allow Radius Compensation Output".
    2) From the 2D Profiling dialog, use "On curve" and "Radius compensation output"
    You also need to define the code for radius compensation in the post processor. (See example below)
    //MadCAM_POST_2014-01-22
    *VERSION*
    5.0_131211
    *FILE_NAME*
    Gcodes with arcs
    *FILE_EXTENSION*
    txt
    *FILE_DEST*
    c:\postfiles\
    *FILTER*
    0.01
    *OUTPUT_WIDTH*
    *OUTPUT_DECIMALS*
    *SCALE_X*
    *SCALE_Y*
    *SCALE_Z*
    *AXIS_1_CHAR*
    X
    *AXIS_2_CHAR*
    Y
    *AXIS_3_CHAR*
    Z
    *PLANE_XY*
    G17
    *PLANE_XZ*
    G18
    *PLANE_YZ*
    G19
    *ARC_RADIUS_CHAR*
    R
    *ARC_DX_CHAR*
    I
    *ARC_DY_CHAR*
    J
    *ARC_DZ_CHAR*
    K
    *ARC_CW_CHAR*
    R
    *ARC_CCW_CHAR*
    R-
    *RAPID_MOTION*
    G00 "x" "y" "z"
    *LINEAR_MOTION*
    G01 "x" "y" "z"
    *CW_ARC_MOTION*
    "plane" G02 "x" "y" "z" "r"
    *CCW_ARC_MOTION*
    "plane" G03 "x" "y" "z" "r"
    *RADIUS_COMPENSATION_LEFT*
    G41 D"tool_radius_compensation"
    *RADIUS_COMPENSATION_RIGHT*
    G42 D"tool_radius_compensation"
    *RADIUS_COMPENSATION_OFF*
    G40
    *SPINDLE_DIRECTION_CW*
    M3
    *SPINDLE_DIRECTION_CCW*
    M4
    *CUTTER_REFERENCE*
    TIP
    *FIRST_MOVE*
    (First move---------------)
    "plane"
    "motion"
    (---------------First move)
    *END_SECTION*
    *RAPID*
    "motion" (---------------Rapid)
    *END_SECTION*
    *RAPID_APPROACH*
    "motion" (---------------Rapid Approach)
    *END_SECTION*
    *RAPID_RETRACT*
    "motion" (---------------Rapid Retract)
    *END_SECTION*
    *APPROACH*
    "motion" F"feedz" (---------------Approach)
    *END_SECTION*
    *FIRST_CUT*
    "rcomp_on""motion" F"feed" (-------------First cut)
    *END_SECTION*
    *CUT*
    "motion" (-----------------------------Cut)
    *END_SECTION*
    *LAST_CUT*
    "rcomp_off""motion" (------------------------Last cut)
    *END_SECTION*
    *DRILL*
    "motion" X="_axis1" Y="_axis2"
    G81 Z"drill_top" U"drill_bottom" B"drill_stepdown"
    *END_SECTION*
    *TOOL_CHANGE*
    ("toolname")
    M6 T"toolnr"
    "spindle_direction" S"speed"
    *END_SECTION*
    *TOOL_STOP*
    (Tool Stop)
    G40
    M5 M9
    (-------------Tool Stop)
    *END_SECTION*
    *PROGRAM_START*
    G00 G49 G40 G80 G50 G90 G64
    *END_SECTION*
    *PROGRAM_END*
    M30
    *END_SECTION*
    *LINE_START_NUMBER*
    Mar 2016
    18
    Is there a way to simulate cutter compensated tool paths accurately?
  1. Tool Compensation Radius Value Question
    By jondojayndo in forum G-Code Programing
    Last Post: 12-17-2014, 01:52 PM
  2. Tool Radius Compensation Question?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-06-2014, 01:32 PM
  3. Tool nose radius compensation on SL-3a
    By cheenky in forum Mori Seiki lathes
    Last Post: 12-10-2012, 08:49 PM
  4. Tool radius compensation.
    By my-cnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2012, 07:37 AM
  5. Tool Radius Compensation
    By davidmb in forum Uncategorised CAM Discussion
    Last Post: 10-03-2012, 10:31 AM
