586,113 active members*
3,052 visitors online*
Results 1 to 6 of 6
    Dec 2015
    34
    switching from mach 3 interface
    I recently purchased this machine, which originally had an AH HA controller, then was upgraded with a Mach 3 breakout board. When I purchased the machine it had no PC, so Im kinda starting from scratch. I just had a new pc built with a parallel port in it, to run Mach 3, but made the mistake of not insuring that it had the 32 bit version of windows. My question is if I want to move away from Mach 3 because its dated, what would be involved. see the attached pics of the machine and breakout board.
    Re: switching from mach 3 interface
    To switch to UCCNC, I'd recommend a UC400ETH. You just need to get a cable to plug the breakout board into the UC400ETH. You'll also need a UCCNC license, and a small power supply to power the UC400ETH.
    This assumes everything was working with Mach3 and a parallel port into that breakout board.
    A UC100 is a little simpler, but the UC400ETH is a better choice imo.
    Dec 2015
    34
    Quote Originally Posted by MAHNKEN View Post
    So can the uc400 replace the breakout board? Seems like a lot of hopping to make it to the ah ha motor control box. Also. I’m not against replacing the Ah Ha box if there’s a reasonably priced option that can swap in
    Dec 2015
    34
    Sep 2014
    129
    The breakout board is connected with a ribbon cable: Breakout boards - CNCdrive - webshop
    No, you keep the breakout board, and plug it into the UC400ETH. You don't have to change any wiring.
  1. tb6560 to mach 111 interface board
    By meatbeast in forum Hobbycnc (Products)
    Last Post: 03-18-2014, 01:53 AM
  2. XML file for Rogers Encoder Interface for Mach 3
    By justCNCit in forum Mach Software (ArtSoft software)
    Last Post: 06-15-2011, 02:05 AM
  3. switching from Win PCNC to Mach 3
    By marianhall in forum Machines running Mach Software
    Last Post: 02-13-2010, 04:38 PM
  4. Mach & cnc router interface problems
    By BlkNotes in forum DIY CNC Router Table Machines
    Last Post: 04-10-2008, 11:22 PM
  5. Need a tach sensor to Interface with Mach 3
    By dneisler in forum CNC Machine Related Electronics
    Last Post: 11-26-2007, 11:38 PM
