586,119 active members*
3,646 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Calculating max acceleration of z based on servo torque
    Nov 2017
    591
    Upgrading my z axis to servo since it just gained a lot of weight with the new spindle setup. Z axis is roughly 70lb, driven by a 5mm pitch screw. Im wondering if a 400watt servo is going to give me the rapids and acceleration i want. I'd like to run 20meter/minute which is 4k rpm at the servo. The 400watt dmm servo has 1.27nm continuous, 3.82nm peak, all the way from zero up to just about the 4k rpm i need. Im assuming peak number can be used. How quickly should i be able to accelerate the z axis upward with 3.82nm of torque on the ballscrew?
    Jan 2008
    1529
    Re: Calculating max acceleration of z based on servo torque
    There are a number of servo sizing calculators available which will give you a good answer.
    Sigma have one.
    Kollmorgen. https://www.kollmorgen.com/en-us/ser...eering-online/
    Nov 2017
    591
    Cool, I'll check it out. Most likely go with 400watt, dmm rep is telling me that it should be more than plenty.
  1. PIC-Based Step Generation With Linear Acceleration?
    By SCzEngrgGroup in forum PIC Programing / Design
    Last Post: 01-08-2012, 09:42 PM
  2. Calculating acceleration rates
    By mcmmach in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-26-2010, 01:55 PM
  3. Calculating torque
    By jakovn in forum Linear and Rotary Motion
    Last Post: 11-07-2008, 05:13 PM
  4. Calculating Reamer Torque
    By Aero98 in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2007, 08:34 PM
  5. Calculating Motor Torque
    By creative_mind in forum CNC Machine Related Electronics
    Last Post: 01-08-2004, 05:52 PM
