586,089 active members*
3,966 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > 5 volt proximity sensor connection to USS?
    Dec 2003
    189
    I ordered a pair of proximity switches that function on 5 VDC. I have the USS powered with an external 5vdc power supply.
    The prox sensor looks pretty standard with 3 wires. brown is V+ blue v- and black output signal.
    I connected the brown wire to 5v on the BOB, blue to GND and black wire to pin 15.
    The led on the sensor comes on when I move a piece of metal near it but I get no indication of it working in the diagnostics screen in Mach 3.
    I have it enabled in the input pins window.
    What am I missing here?
    Is a sentance fragment?
    Apr 2007
    33
    Re: 5 volt proximity sensor connection to USS?
    Quote Originally Posted by Tristar500 View Post
    Check your ports and pins input screen and change the input from hi to low or visa versa that should do it. If not then using a volt meter check the BOB to make sure no broken wire.
    Nov 2012
    1267
    Are the switches PNP or NPN?
    If you disconnect the switch and short the input to the GND with a piece of wire, does the input state change (in the diagnostic screen)?
    Dec 2003
    189
    I ended up purchasing a opto isolated relay board and fixed it that way.
  1. Having issues with Proximity Sensor
    By john_in_Tacoma in forum Avid CNC
    Last Post: 07-12-2019, 11:13 PM
  2. Replies: 3
    Last Post: 06-26-2018, 06:56 PM
  3. Npn NO proximity sensor question.
    By silvs in forum CNC Machine Related Electronics
    Last Post: 05-03-2018, 06:59 PM
  4. CRP's Proximity Sensor Kit
    By rwskinner in forum Avid CNC
    Last Post: 02-12-2014, 04:07 AM
